Snapper pro crusier
e.fuddyduddy
Have a pro crusier,with22h. Kohler command that will start,run fine for a bit,sometimes20 min.or so,then shut down for no reason,just like you turn off key.I have put new fuel pump on ,new fuel shut off on carb,checked and cleaned all plug connections.Dose this mower have a safety kill switch for engine.oil is fine,pressure is fine.It will also die immediately if I try to start mower,but not sputtering die,just like you turned it off
Next time it dies, check for spark. Could be a coil going bad due to a hot short or hot open. If no spark, time to replace the coil.
e.fuddyduddy
It is a twin engine,has 2 coils?.I could see that if it only had 1 coil,but both plugs die at same time
The kill wire between the coils could be hot shorting to ground.
