SNAPPER LAWN TRACTOR LT160H42HBV2
maybe
My PTO disengages while cutting and i turn off and then back on the PTO switch and it engages for awhile. new PTO switch has not solved the issue. Any suggestions, thanks
maybe
also the OPERATOR PRESENCE AND PTO RELAY WAS INSTALLED NEW as well
PTO will only dissengage if
1) it gets too hot
2) voltage drops below 10V
3) momentary break in either + or - wire
4) one of the safety switches is faulty or there is a short in one of the safety circuits wires.
maybe
1) it gets too hot
thank you, its appreciated.
