snapper 331416bve rear engine rider belt coming off
wecwec
I have replaced belt, and am sure I have the correct belt. Tried running before I put plastic cover over belt deck, and when I engage the idler pulley, the belt will slip off. Is there an adjustment I need to make? one of the pulleys is slightly bent, should I replace that? Will that solve the problem?
Perhaps I need to level the deck? but it was not a problem before?
Suggestions. Help. All appreciated
