Simplicity Regent SLT 100
CDAN
My Simplicity Regent SLT 100 (2016) do not work well on backwards : much too slow ?
Thank you for your advice/CDAN
Catherine
LawnWorld Support
Staff member
Hi and welcome to the forum!
I'm going to move this thread over to our Simplicity section to see if we can find you an answer.
mechanic mark
check tire air pressures first, post your 7 digit model number, remove deck inspect drive belt & idler pulleys for replacement, use OEM Simplicity replacement parts
CDAN
Model number is : 2691218
With system Hydro Gear
