BTW the jack stand is on the front cross bar not the mower deck.According to manual you should have 4 wheels on the deck.
Simplicity use ground engaging decks so the wheels follow the ground while you are mowing.
Thus if there are no wheels at the front there will be too much load on the front mount.
People take them off because the mower seems to cut fine without them and they tend to get stuck on any protrusion in the grass.
You can download the parts book from Simplicity.
Well it should have an electric clutch on it that should look like this https://www.stens.com/search?keywords=1708536
What I see in your photo is either a manual clutch pulley or a manual pulley grafted onto an electric clutch.
It looks like only the wheels in the back. A line of them. No marks on the front where they were ever mounted. There are a couple bolts. But they are there to hold metal in place on the inside by the blades.... You can't see the rear wheels in this picture....
It sure did take a bite out of this mount. You can see where the secondary mount was wearing on it..
Fixed up before the paint...
Not meaning to sound preachy, but that is why we are always begging people to post the full mower model numbers from the tag under the seat, although simplicity put it on the side of the frame from memory.
Simplicity used to put tags on their decks as well.
<<<< I will remember that in the future...
Nice piece of welding but now that you have painted it I am really going to annoy you.
A weld is a casting and castings are weaker than wrought steel so you will need to put a brace over the welded area.
The heat from the weld will also have softened that side so I would run a strip of the same size steel full length on the outside .
I use old blades as I have tons of them and a small forge to flatten the curves & bends.
<<<< Sounds like a good idea. Most of the steel was still there... I wanted to grind it smooth and fill it in, so it is not sharp to tear up a new belt.
Now for some worse news, it looks very much like your bottom oil seal is gone on the engine.
So untill you have time to pull the engine & replace it keep an eagle eye on your oil level and the sooner the better, there is not much oil in a mower engine to start with and they all rely on splash to lube the bore piston pin & valves.
<<<< Yea trying to get her to keep an eye on the oil level. From what I could tell. The oil was leaking from the valve cover. I took care of that, but I did see the drip in the picture.
I don't have an IPL for that deck but it looks like it hangs from one side so check the lift / height adjuster to see if it could be connected to both the outside & inside of the mechanism on the mower.
If it can then refit it connected to the inside which should push the rear a little to the left.
<<<<It only has a lift cable on one side. It looks like it is only used to lift the mower for transport. But I will look next time a see if there is an attachment on the other side for a second one.
I have the identical problem. Same Simplicity Regent with 38"deck. My father also owns a newer version (2014) of the same lawnmower. His has the same problem as well. There clearly is too much play allowed by the Simplicity single point mount. The problem on mine seems to be too much play where the deck is bolted to the hitch. I wrapped some electrical tape around the spacer for the bolts that connect the deck to the hitch.
So out of curosity when you change the cutting height does the rear of the deck raise & lower.
And are the blades actually leveled ( they should be about 1/4 lower at the front.
Part of the problem could be that the deck is sitting lower at the back.
And yes, a good idea on paper, but not the best on the grass.
In Brian's case it was due to the mounting bracket for the height adjustment which he photographed in post # 11.
Being that there has been 3 people with the same problem one can safely say it was not a good design .
OTOH there were thousands of them sold and to date there are just the 3 of you with the problem so it might also be something with the way the mowers are used or maintained.
Just replying back. It is a lot better. I need to stop over and get another look at it. I believe there are a lot more people with the problem. I think most don't care. I am very mechanical so I look out for things that are not right. My Mother never did notice it, sparks, grinding and all. Of all the people with the mower and deck combination, who notice it, and make it to this forum, I think 3 is a pattern.
tmyers, I would take the deck off. Clean the sharp edges of the deck. (file or small grinder) Careful they are really sharp. Make sure all the bolts are in place and tight. Make sure the spindles and idle pulley are free. I think you have to set the deck on a block of wood to spin them or they sit on the ground. It is a pretty decent mower. It is still running now.
Strange it only hits the bracket turning one direction.
