Simplicity Broadmoor
hbrand55
steering wheel turns with no turning - shaft spins - if I pull up on the steering wheel it will turn.
Is there a fix?
Time to replace the sector gear and/or steering shaft gear. Seeing you failed to give us a model number it is hard to say the shaft gear is removable or part of the steering shaft. If you decide to complete the work get new bushings or bearings and replace them also.
