Have a 19 yr old Simplicity Broadmoor 16 HP Hydro mower, model #1692776. Mower was starting and would run fine right after it started, but after about 10 or 15 minutes of mowing it got progressively slower and slower until it would barely move. Engine was still running at full speed, but the mower wouldn't move. Figured the main PTO belt needed replacement after almost 20 years, so swapped it out with a new belt. Appears to be on correctly, but now I can't start the mower. PTO is off, brake pedal is pushed down, seat interlock switch engaged, but although it started fine with the old belt, I'm not even getting the engine to turn over with the new one. The only thing that you do that seems at all tricky when changing the belt is that you have to drop the electrically operated PTO to get clearance to remove & replace the belt, but then you put it right back on the engine shaft, which didn't seem that hard. However, I figure I must have messed up something, but I don't see anything obvious. Any ideas?
Until I can get it running, I won't be able to find out if the belt swap helped with the original problem (slowing down after it ran for a while).
