Buying Advice Shread an Vacs.
I have a craftsman blower/vac I run at home. Was on sale for like $89. Had it 3 years. I use it mainly as a blower. Vac works good in corners around the house. Bag fills quick if you try attack a large pile. It has the plastic fan blades so I try not get any rocks, pinecones, or sticks.
Have a piece of junk tanaka at work that the only thing I like is fan has a small metal shredder blade first then the bigger plastic fan. Never used it as a Vac.
