Should I be concerned with an damaged/enlarged Emulsion Air Intake Port on my Walbro LMT 5-4993 carb'?
GAJoe
  • / Should I be concerned with an damaged/enlarged Emulsion Air Intake Port on my Walbro LMT 5-4993 carb'?
I don't know how it got opened up more but you can see that it is enlarged.
If it causes a leaner emulsification can it be corrected with the adjustment screw. Or does that fixed jet that screws in straight down next to the adjustment screw control that mixture? That port and the Air Intake Port is where Carb cleaner come out when I spray into the bottom of the emulsion tube with the top of it covered with my finger.
