wjjones,
Same here, except I use the bench grinder. The cone balancer must be a "Tennessee thing" as there was a huge debate in a thread about that method versus using a nail in the wall and the "expensive" metal balancers(that run a couple hundred bucks). There was also varying opinons as to the real necessity of balancing the blade(in regard to performance or adverse effect on spindle assemblies/bearings). This is likely to re-open that debate:0)
