Briggs Model 90702 Type 3090-01 Code 88031724 Is the shaft diameter .90? Thanks much
A AndyK Member Joined Nov 11, 2017 Threads 5 Messages 13 Feb 1, 2024 / Shaft size #1 Briggs Model 90702 Type 3090-01 Code 88031724 Is the shaft diameter .90? Thanks much
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Feb 1, 2024 / Shaft size #2 Shaft sizes are thankfully standardised 0.875" - 1"- 1.125" -1.250" after that you are in agricultural equipment In the EU that as 20mm 25 mm & 30 mm so 7 different shaft sizes to choose from .
A AndyK Member Joined Nov 11, 2017 Threads 5 Messages 13 Feb 1, 2024 / Shaft size #3 Thanks!!! This helps!!!
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 123 Messages 12,913 Feb 2, 2024 / Shaft size #4
