Self propelled gears not engaging
Jack9
My Craftsman mower is rear wheel drive and has a Honda engine. It's about 6 or so years old. There are two metal gears that are supposed to mesh together to drive the wheels. One is a larger gear attached to the wheel hub. The other is a smaller one that is attached to the drive axle. The drive gear spins but is not engaging the wheel gear. The rear wheels are fairly new.
Again, these are both metal gears. This is not the typical problem people have where the metal drive gear wears out the plastic teeth that line the inner wheel rim. Mine doesn't have that type of system.
Does anyone know how I can get these two gears to engage?
Jack9
have you disassembled & inspected other parts for wear or tried lubing or greasing assemblies? post your sears model number beginning with 917.
I looked it over, including underneath, but didn't notice anything right off. I haven't greased anything as I don't see anything that could be.
The model # is 917.374910
Did you check to see if the pin behind the gear is still there or has fallen out? Pin drives the gear.
Jack9
You mean the drive shaft gear, correct? I'll check it, but wouldn't that make the gear not turn? Or does it keep it in place, which is why it might not be turning the wheel gear?
Jack9
I guess I'll order new drive gears. I doubt they'll last very long though. The problem is they're too far from the wheel gear, which is how they ended up worn out to begin with, as there isn't enough contact area, and they're just riding on the the peaks of the gear. Then once it slips, it ends up grinding the gear down and making it even worse. I guess it's just a very poor design.
tom3
Maybe a worn bushing or shaft that is allowing extra clearance between the gears? Or a slipped mounting point? Maybe flip that drive gear over and wear the other side? Looks like decent components with a poor setup.
tom3
Just out of curiousity move the height adjustment up and down, see if the gears mesh improves?
Jack9
The axle/drive gear sure is worn with that lower shelf. Only $6.32 on the sears site. https://www.searspartsdirect.com/mo...-917374910-gas-walk-behind-mower-parts?page=2
If the gear was the same on both sides, you could flip if over and wear down the high side.
I'm just afraid it will quickly happen again to the new gear.
You can't flip the drive gear because it has notches on one side that two pins that the drive shaft fit in that enables it to turn the gear.
