Sealed hydrostatic transmission
Nuclear
Anyo had any luck draining a Hustler Raptor sealed hydrostatic transmission.
I know they're supposed to be sealed and never need the transmission oil changed but oil breaks down over time and use.
You remove each unit, remove the vent (oil fill port) fitting, and turn upside down to drain them.
Need the model number from serial number tag to look up the IPL to verify. But this normally how you change on unit without an external oil filter. IF has external oil filter then you would simply remove the filter. That is a different procedure as they would be different hydros.
Nuclear
Okay they are Hydro Gear ZT-2200 EZT unit and instructions in post #2 is correct.
Very fun to do isn't it...
