Repairs Scott's lawn tractor model L2048
samber4
Hello,
New to the Forum, and not exactly sure how it works but giving it a try. I have a Scott's model L2048 lawn tractor. I am having some mobility issues right now. Even when I have the accelerator at full speed, the tractor barely moves, and if I put it in reverse hardly at all. Since this machine has a sealed transmission, I was wondering if the problem may be the drive belt. Could this possibly cause the mower to function so poorly? If so, is it fairly easy to change the drive belt? Thanks for taking the time to read this. Any help would be appreciated. Sam :smile:
Sounds like it could be the drive belt. Also, check the belt tensioner and make sure it is moving freely. Not the hardest job on a tractor, depending on your mechanical ability.
