I have a Scotts 2550 25HP Kohler engine. My wife was using it and the engine stopped. That's about the best description I can get. After some investigation I suspect an engine problem.
I'm wondering if I should be able to turn the engine by hand using the nut/bolt on the top that id in the center of the fan? If so, how much effort should it take?
I've eliminated the starter and battery and removed spark plugs.
Thanks,
Dennis
Thanks,
Dennis
