Atglenhillbilly
- Jun 3, 2013
- 10
Hi everyone. I bought a used scag wildcat zero turn. I changed all the fluids and replaced the battery and everything was running good. Then the last time I mowed when I shut the key off something kept running. The motor shutoff but something else was running maybe starter or pump of some sort. I switched the key back and forth a couple times and it stopped. Then the next time I went to start it the engine didn't crank and the thing that was running before started running and when I turned the key off it kept running again. I switched the key back and forth a couple times and it stopped. I replaced the ignition switch today and it still keeps happening. Sometimes it will start the engine but most of the time just something electrical starts running and doesn't stop until I switch the key back and forth a couple times. I'm lost. Any help would be great. Thanks
