Export thread
Sag cylinder cuts out
#1
A
Apex
I have a scag t.t. 04. Kawasaki engine. Problem is intermittent right hand cylinder cuts out, If I wiggle the fuse (behind the instrument cluster) just right it will return to normal, maybe all day, or for a minute, it seems (fuse) to get hot when firing on both cylinders..... Took to 3 different dealers..... cannot seem to locate the Problem, after fixing many electrical items, I need to figure it out myself, can't keep spending 5 -$600 every time... getting. back still with same issue ,THANKS,
Brian
#2
BlazNT
BlazNT
What does that fuse go to? Model number and build date so I can find your manual or wiring schematic.
