s130 will not start
ACF
have a john deere s130 that was running great now it does not want to start when you turn key there is no clicking at the solenoid you can jump solenoid and it will start, replaced solenoid still nothing changed out key switch still nothing seat switch changed out nothing, so looking for any help in resolving issue also is there a way to test seat switch,
thanks in advance
This is called guess work. It can get very expensive and still not the problem.
Someone needs to hold your hand and walk you through how to trouble electric problems. Hint> Ignition, PTO, Brake, and Reverse switches are all in the starter solenoid (relay) trigger circuit.
You’ve posted 2 threads with the same problem and have done what experienced techs never do, THROW PARTS AT IT TO SEE WHAT STICKS. As Star said you need someone to hold your hand and I will give it a try, but I’m assuming you have some electrical circuit knowledge. Here are two procedures on how to pinpoint causes of electrical problems. If you don’t understand them time to find someone who does.
Here is how to test relays.
To test a lawn tractor relay, you'll need a multimeter and a 12V power source, like a fully charged battery. First, identify the relay's terminals: typically, terminals 85 and 86 are for the coil, and 30 and 87 are for the switch. Apply power to the coil terminals (85 & 86), and a good relay will click. Then, check for continuity between terminals 30 and 87. A good relay will show continuity when the coil is energized (clicking) and no continuity when de-energized.
This is the procedure I use. Report back with your findings and we’ll work from there.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
sgkent
not piling on. A simple volt ohm meter from your local Harbor Freight, or Amazon is the first thing you should buy rather than fire the parts cannon. You can have a bad part or a chewed wire. The parts cannon will bring on a great frustration if all you do is keep firing it.
ACF
ACF
1. fuse is new and tested good battery connections are clean and tight battery voltage is 12.88
2. voltage is 12.88
3. purple wire is 8 and dropping fast as i leave the key switch in start position
ground wire was .006
4. terminal to starter was .015
5. power at starter was .037
6. solenoid is 4 wire checked back to battery via continuity check test good
voltage after test 12.83
sgkent
1) What is battery voltage between the positive battery clamp and the engine case when the key is in the start position?
2) What is the voltage between the positive battery terminal and the engine case when the key is in the start position?
If you have no voltage in step three, that would indicate to me you need to check the following. This is the times where even experienced technicians start to pull their hair out and question their sanity. Good Luck.
1. You say you changed the key switch and. Have you checked to make sure both the new and old switches are exactly the same. They may look alike, but the terminals may not be in the same position. Terminals should be labeled.
2. With the switch removed, check the key switch for continuity between the B terminal and the S terminal, with the key turned to the start position. It should read 0 Ohms.
3. If the switch is good you must now locate and check each safety switch for proper operation. This means seat, brake and PTO switches.
4. If all safety switches test good you will have to check the wires between each component, looking for something broken or frayed and shorted.
