RZ4623 Shredding Deck Belts
Kaladin
Hello everyone, I'm trying to figure out the issue with my zero turn rz4623. It keeps shredding new belts. When you replace the belt it works great for maybe 30mins then the belt comes off shredded. I can't see it rubbing anywhere and from what I can tell nothing is bent. Any ideas?
That is not much information you are giving us to work with.
Some photos of the belt might be a good start as the damage to a belt will tell us how it failed.
Usually a belt that expires in such a short time is because it has been installed on the wrong side of one of the belt keepers .
After that have a good look at the pulleys for one that is jambing or has something wedged into it.
Kaladin
I'll try and get some pictures tomorrow. Thanks for the reply.
