primerbulb120
- Nov 3, 2014
- 1,315
These carbs don't have the original part number, but I think they will work. They look similar enough to the original. I buy a lot of parts based on how they look rather than part numbers.
hurst1979olds, I recommend that you purchase an adjusting tool before buying a new carb. You may be able to adjust the old one and get it working. That way, if you purchase a new carb, you will already have the adjusting tool. A new carb will probably work but may need a little adjustment before the engine runs perfectly.
