Cars_to_mowers
- Oct 16, 2015
- 1
- 5
I'm completely stumped as to what is wrong with this thing. It's a SEARS craftsman eager-1 4.5hp 22" engine model 143.964502.
It starts on the first try, runs for as long as 10 minutes, and as soon as I'm cutting a thick section of grass it starts surging and then dies. Then it won't restart (no kickback, just smooth pulling and no start.) unless I wait like 30 minutes. After that it starts but shows the same behavior.
I replaced the ignition coil, air filter, and spark plug. I removed the bolt on the bottom of the carb and cleaned the [one] hole in it, no change. I've removed the spark plug when it dies and it looks dry. No fuel, which suggests a fuel starvation issue.
I got the mower from a guy on craigslist and it has done this since day one. I'm an auto mechanic so I'm mechanically inclined but I have no clue how to fix this thing.
A few things I noticed:
It doesn't have a primer bulb rubber thing. It's my understanding that this section of the carb should have a bulb. Can a missing bulb cause issues?
Also does that flywheel key look OK?
