mickymower
- May 10, 2013
- 4
I got my riding mower out after the winter, it took a while to start as the battery was flat. I got it to work and mowed for 1/2 hour. I stopped the mower and 2 minutes later tried turning it back on but it wouldn't start. The motor was making lots of banging noises when I tried to start it. Eventually it made a big bang then the battery went flat again. I tried pushing the mower in neutral but it wouldn't move until a neighbor shoved it backwards and forwards and it started to push again. What could be wrong with it and how do I fix it? I hadn't put any oil in it for a while even though its only had 20 hours of running from new.
I didn't check the oil, I just put non-ethanol fuel in and off I went ( i never read the label that says check oil every 5 hours of use until now). I have put some oil in now, SAE 30. I think I screwed my weed whacker up last year by not putting any oil in that either.
