Interesting, how is it attached to the mower, welded or bolted to the full frame or the front end? How does that much weight hanging off the front end effect the balance of the mower?
Tom
Ron,
That rig is looking good. When I first looked at it I thought you were using a form of the tension springs like on garage doors, the ones that when someone that doesn't know what they are doing tries to work on them, end up calling a pro and 9-1-1. ;-) Looking at it now I think the springs you are using are the flat straps looking ones running between the upper and lower bars or am I still confused? (That happens a lot) Where did you find the springs that you are using?
Tom
