silver1
I had to rewire my rider after the last owner butchered the wiring with a newer key switch.
It turns over and starts with all the safety switches working. It only ran for a short time (gas).
I"m not sure if the Off (M-G) position will kill the engine. I have the "G" terminal going to
frame ground. The "M" to the black wire from the engine.
My question is How do you know if it will "kill" the engine? What test will confirm kill?
LB
LB
