sgkent
- Sep 27, 2017
- 35
- 1,795
Update 4/12/2023 - problem solved, parts replaced. Weak side had a broken inner E-clip lying in pieces inside the clutch mechanism. PDF showing photos and details of repair. Kudos to Rivets for helping out.
http://kentcomputer.com/toro/torocr.pdf
Original post:
2006 or so 21" rear wheel drive super recycler. Replaced the belt and lubed the bearings thru the zerk fittings last week. Really takes off now when the traction bar is pushed forwards but the mower torques left as it takes off. Never noticed it as the old belt was growing tired. I put the mower on concrete and gently lifted the wheels evenly as I pushed the traction bar forwards, and while both wheels have good spin and traction, the right rear one takes a lot more friction to stop. It appears to be getting the bulk of the power, and the left rear gives up much earlier. Does the transmission have friction clutches in it or something like that, or is this by design? The wheel spins evenly and does not skip, so it is not like wheel drive gear is stripped, it just gives up easier than the right one does, which I suppose is why it is torqueing left when we take off to mow, It is significant enough that it could be dangerous to someone not anticipating it.
Original post:
