Rescued from the dumpster - 7260D Lawn Boy...
Lawnz 420
Pulled this out of a rollaway dumpster last night... poured a bit of mix in the tank, primed and pulled the cord...and it fired and stays running for as long as you keep pressing the primer bulb. Deck has no cracks, wheels are straight and the blade is usable with a sharpening. Unfortunately the bag, mulch plate and maybe a few other things are missing in action. Plan is to clean it up some today and begin the search to obtain the missing pieces...any assistance with locating parts or necessary information on this 40 year old classic would be appreciated. Thanks for looking at it!
fabricgator
SCORE!
A trick to keeping it running, open the airbox and remove the filter. Get it running and while it is running try to restrict the air inlet suction as good as you can get it. It is like choke, but what I am trying to do is to use the engine vacuum to suck/clean a clog in the jet or a vent of the carb.
I fixed a outboard motor like this onetime with a golf ball. It was a three carb 70hp JonnyRude. It would idle fine but when you got it up and running one of the cylinders was intermittent so it would run on three (1/2 power {not a third because of friction/compression}) and it would jump to full power occasionally. I checked/changed all the ignition stuff. We were out for a test run and it was still acting up. I removed the cowl cover and the front of the airbox. It was so oddly shaped that I could not get a good enough seal on that thing while offshore. Funny enough, we hit a wave and of all things a golf balled rolled out from somewhere and it was the perfect size and shape. I had Becky at the helm, open her up and while wallowing along just on step, I shoved that golf ball in there and it Schlluuu (suction sound here) and then I pulled it and she jumped up and ran like a champ. Never had a problem from that point.
This is an old trick showed me by a mechanic as a kid. 1970 Impala w small block chevy , air cleaner removed. Rev it up and place your hand over the intake... Schlluuu....
Lawnboy77
Nice find! Your engine is an F series, a 7260D is a D series. An engine swap happened for whatever reason, no problem with that, but to order parts for the engine use a model number like 7268. Once again, that's a great little mower you have there.
2smoked
That looks like a nice find! It is very similar to the first Lawn Boy I bought new 36 years ago and still use. It doesn't appear to have been abused--probably just needs a little TLC like cleaning the carb, the exhaust port and muffler, but you might already know that. I would also replace the crankshaft seals. The fact that it fires is a good indication that it doesn't have any major problems. Hopefully the cylinder, rod, and piston have not been damaged by running on straight gas or improper mixtures. A little bit of disassembly will reveal a lot.
I love those early F series mowers. They were well made. Some photos of your finished mower are always appreciated. You should feel proud to have saved it. It is surely not a hunk of junk.
There are a good number of sources on the web for parts, including "Fleabay".
2smoked
You are correct Lanboy77, I failed to notice that there was an engine swap. But that surely would not have stopped me from saving it too.
Phototone
Engine, or deck swaps seem to have not been too rare on LawnBoy. The "D" and the "F" engines muffler plates fit the same hole in the deck. Perhaps the swap was more to do with the owner broke the deck, and found a salvage deck to mount his good "F" engine on. The aluminum or magnesium decks can be broken if you hit a rock. If the engine only stays running when priming, then you got a dirty carb. Taking it apart and cleaning the main jet should solve the problem. Be sure and replace the wire screen mesh filter over the jet in the float bowl, either clean and re-install or replace it. You have to pull it off to get to the jet anyway.
Lawnz 420
Update...it's the magnesium deck and there's no cracks in it...so I removed the engine cover, cleaned the gas tank out, replaced the fuel hose, cleaned the carb bowl, cut a rectangle of foam to replace the rotted air filter, cleaned/regapped the plug, sharpened the blade...and fabbed a sheet metal plate to cover the deck cutout until I find a factory mulch plate for it. It now starts on the first pull and runs pretty smooth at both the low and high speed settings. Went and did a lawn with it...cuts well and it spits the grass out the side for a good distance. Only issue is a little oil on the deck from the crank seal...I understand better now the love for these machines, the smell of a lawn being cut with a 2 stroke is sweet:thumbsup:
Crnbinder
Great find you can't beat those old lawn boys IMO the best mulching mowers ever made
I have a 7268 very light and powerful , a spectacular cut , and what a wonderful aroma
eBay will have all the parts you need
Lawnz 420
I was at work on a yard yesterday when the boss said...I just remembered...Mrs. Shaeffer had a old Lawn Boy buried in the back shed there, you should ask her about it. I did...she said she thought her grandson took the mower a couple years ago, but I was welcome to it if it was still there. It wasn't, the grandson must have dug it out...but he left some parts behind, basically everything I didn't have:biggrin: Got the discharge plate, the mulch plate, a green bag chute and the matching grass bag:cool: Though the parts are newer than the mower, all the plastics are in great shape and thankfully the mice didn't chew up the bag... I've been working on the bag rod and the handlebar chrome, polishing with aluminum foil...and they're cleaning up nicely. Next thing I need to get are new wheels...
2smoked
That whole package looks real nice. You say you are looking for new wheels, however, the pictures show that they don't look too bad. If they are wobbley, maybe all you need are new axle bolts along with adding bronze bushings to the wheels. Just drill out the centers to fit the bushings and those wheels will roll better than new.
