Replacing Drive Control Cable 946-04440.
cprodave
On Troy-Bilt 21inch 7.75 hp Professional model 12AI869F011 what is the easy way to replace Drive Control Cable 946-04440? I am thinking I can remove the Blade and then Plastic Baffle(s) above the Blade to gain necessary access. Thanks for any advice...
This video may be of some help.
cprodave
Thanks for the input but the video you reference is for a front wheel drive vs. Rear-wheel drive (which I am trying to fix). I have replaced belts/cables on the front-wheel drive Troy-Bilts before, but this rear-wheel drive is entirely different design.
