stinger024
- Sep 16, 2018
- 1
- 1
Hey guys.. newbie from australia here..
I have a greenfield fastcut34.. was powered by a briggs and stratton 19.5hp Intek.. I've purchased a b&s 19hp pro series motor to replace it.. got a new solenoid as well..
Have fitted the motor and replaced the solenoid.. have wired to the starter and block for ground.. now the engine will spin no worries when I turn the key but it doesnt fire up..
The wiring was a bit different.. I'll attach some pics in the hope of some guidance to wire what needs to be wired..
Behind the ignition there are 5 spade connectors marked B G L M and S.. the new motor has a 6 port plug attached with 4 wires going into it.. (and of course it's not plug and play haha)
I've removed the wiring for the lights and clock as someone had butchered them a bit and I have no need for them..
