Replacement engine for Kholer engine on a zero-turn Toro
jfpresl
  • / Replacement engine for Kholer engine on a zero-turn Toro
Where can I find a chart or some other way of cross referencing to find a new engine for my Toro. When I go to any web site, including the Kholer web site, I can not find the engine that is on my mower. Below is a pic of the label on this engine.
Family 9KHXS.5972GB
MODEL SV590S
SPEC NO. SV590 - 0212
SERIAL NO. 3904924563
Kohler has stopped making the Courage engine, short blocks are available but are expensive. Any engine that you choose to replace your current engine with will require a new exhaust or you will have to make or modify the current exhaust, and if you change brands may have to rework the wiring.
