Replacement engine for Exmark
Hobby Farmer
I have an older Exmark, model V48-14K-H, that needs a new motor. It was running the Kawasaki FC420V until it decided to blow up the other day. I was given a Kohler Command 23 to use but the oil filter interferes with the clutch engagement lever. What other engines would work as a replacement that are available today?
