Engine Replace Hydraulic valve lifters on Kohler CV13s engine
jrod
  • / Replace Hydraulic valve lifters on Kohler CV13s engine
I've been having engine problems with my old John Deere LT 133 mower keeping it running. I've finally narrowed it down as to why it would start easily one time and hard the next time. Finally it won't start. Only back fires thru the exhaust and carb. The exhaust valve is not closing. Looks like the hydraulic lifter is stuck.
How do I go about replacing the hydraulic lifters?
Nwatson99
See if this will help you:
WoodCarver
Jrod,
I have the same thing going on with my JDLT133, did you get it fixed? if so can you share? thanks
:welcome:
Jrod only ever posted once in 2014
Hit the link in the second post and get your service manual fom Kohler.
Because of the bucket construction Kohlers are easy to work on and once you remove both belts they can be services in the mower
WoodCarver
:welcome:
I have tried the link provided but I can not seem to find a manual for CV13S. it comes back with nothing.
reynoldston
Don't use the S on the CV13S its a letter that John Deere uses. Look for a CV13. Its under command PRO 11-15 HP vertical
