Regulator/Rectifier
gregjo1948
Briggs reg/rect #795067 YP081113. 2 wires red&green- red is hot - yellow goes to stator( only wire to the stator) How can I check reg. to see if is working. Thank you,Greg
motoman
Greg, I have an intek manual which has a good troubleshooting section. See if you can get a manual for your engine.
