A few months back, I acquired a pristine 10518. Engine ran good once warmed up. Took some effort from the primer to keep it running. After about 30 seconds, it would purr. I did notice when mowing , it seemed to lack power. With it at near
full throttle, it would bog to the point of dying when you hit 3'' tall grass. My duraforce could be pushed through 6'' of wet grass and keep on rocking. Between the low power and hard to keep running, I chocked it up as needing crank seals and put it away for the moment. Only got the chance to mow twice with it before mothballing it.
aw
I drug it out today and got started tearing it down. Didn't notice any oil leakage around the seals, but I did notice something broken on the carb ( see the pic with the bailing wire) and upon removal of the exhaust, I could see scoring on the piston. I decided to further tear it down. The connecting rod seemed kind of sloppy at the crankshaft and the needle bearings fell out upon taking the cap off. Not sure if there was some sort of a holder that came apart or if they get installed with a dab of grease to hold them in place. Is it normal for them to have play? The crank looks to be in really good shape. The reeds look like new.
The cylinder is scored up a bit, but nothing deep. I think it would clean up with some honing.
So as best as I can tell, need a piston with rings, possibly new needle bearings, a cylinder gasket, and a carb. I realize I wont find the carb or piston on any of the usual parts sites. Does anyone have part numbers that I can use to check ebay?
The wife got a kick out of me hoisting the mower to my work platform. I have major back issues and try to lift as little as I can. Hung a chain fall from my porch and was able to do all my work without lifting anything other than the engine.
aw
