rear wheels of honda self-propelled rear wheel drive
tominky
Can an average guy replace the rear wheels of my Honda self-propelled rear drive or would this be too complicated and need to go to a repair shop?
primerbulb120
It's very easy and I'm sure you can handle it. Just remove the bolt in the center of the wheel and the wheel will come right off. Then you put the new wheel and bolt back on. There is a washer behind the wheel that will fall off when you remove the wheel, put it behind the wheel when you re-install.
:thumbsup:
