Rear wheel problems with Toro 190cc 7.25 Mower
Tomski5025
I purchased a Toro 190cc 7.25 hp mower the end of last year. The rear wheels on this mower only go backwards when the mower is off. I read manual it stated to stop let the reverse click in and then they will move backwards. However this doesn't work. Any suggestions???
Post the mowers model number for a more specific answer. Have you tried to loosen the drive cable? It goes down the left hand side of the handle, from the personal pace controller to the tranny. Loosen the nut and move the cable 1/8" up toward you and tighten the nut. Test and report back with the model and serial numbers.
