Export thread
Rear engine snapper won't turn over
#1
R
Remmy039
We had it running the other day and when I put everything back together it won't turn over. I checked voltage to the regulator and 12 vdc is going out of the regulator when I turn the key on. Checked all wiring could not see anything loose. What is next step, check voltage to starter?
#2
G
gvanek
is your solenoid clicking? Where do you stop getting power?
#3
R
Remmy039
I found the safety switch and rear of mower was not engaging. Fixed that problem and she turned right over.
#4
G
gvanek
Awesome! Glad you figured this out.
