Ealier this month I picked up a 15 gallon sprayer with a broad cast wand to spray the 2+ acres of coast Bermuda grass we have. The directions stated that it will spray a 14ft swatch at 36" high.
Anyways, armed with a stick of steel, abrasive saw and welder, I built a rack above the engine. Here is the final product minus paint. Still trying to decide if I want to go with Yellow or Black for paint.
I built it so I can remove it as need be. It does not get in the way of the air filter, oil filter or throttle cables.
