Question About Blade Movement on Lawn-Boy 10682
Xpseven
Hi everyone,
I have a Lawn-Boy mower, model 10682, that was inherited from my grandfather who passed away. I'm changing the blade and I've noticed that when I turn the blade half a turn, it drops about half an inch, and when I complete the full turn, it rises back up. Is this normal behavior, or could there be an issue with the mower?
The blade is properly secured, and the height adjustment is on the wheels. The shaft comes directly from the motor.
Any insights would be appreciated, as I want to keep this mower in good condition as a tribute to my grandfather.
Thank you!
P.S. English is not my first language, and this note was partially translated with the help of an AI. Please excuse any mistakes.
Bent blade.
Xpseven
Bent blade.
Thank you for your response. No, the blade is new and straight. Also, if it were bent and both sides uneven, one side would always be higher than the other. However, every half turn, both sides change in height. Do you understand what I'm saying?
bogdaN
Bent crankshaft.
Honest Abe
Hi everyone,
Thank you!
was it running prior to the blade change....?
