Putting a little Oil in cylinder before initial start of new small engine.
ajd2
  • / Putting a little Oil in cylinder before initial start of new small engine.
What are your thoughts regarding placing a small amount of oil (1-2 tablespoons) into the cylinder through spark plug hole and pulling the pull start to prelube the cylinder prior to initial starting of the engine. I have heard that some people recommend this as it can lubricate the cylinder walls, piston rings, etc. What kind of oil do folks recommend? Regular engine oil?
Tiger Small Engine
Make sure the engine has oil and it is at full mark. If you want to add a little oil down spark plug hole and crank it over a few times, nothing wrong with that at all. Remember that long term engine longevity for your engine is regular maintenance including oil changes, checking oil, and watching the air filter to keep it clean.
hlw49
Have never done that but sounds like a good idea. What about fogging oil? Take the plugs out turn each cylinder to BDC and treat it with the fogging oil. It would be much easier to get it into the cylinders. Just a thought.
Auto Doc's
New engines from the factory already have assembly oil coating all of the internal engine parts before the crankcase is initially filled.
To me it is not necessary to put oil in a cylinder that will likely disrupt the spark plug from firing.
Proper oil level and changes from day one is the life of any small engine.
Never a concern about getting all the break-in metal out. Every new or rebuilt engine will have a ton of metal flake in the sump.
Auto Doc's
Yep,
I had to tell a customer recently to quit flipping his push mower over to sharpen the blade because that old break-in sludge would kill his engine. He would not listen to reason, so it cost him an engine in one season of mowing.
Skippydiesel
Yep,
You should have told him that sharpening the blades has no significant benefit, other than to the blade supplier 😈
Skippydiesel
I have never put oil directly into the cylinder of a new engine - Remember, as soon as that engine fires/starts, any oil in the cylinder/exhaust/inlet will be burnt off - there will be significant smoke, which may make you feel good or not, as the case may be. 😈
andrewslarge
Nothing wrong with a teaspoon of oil at the end of season through the spark plug hole, and then bring the engine to close the valves at TDC. It’s in the Briggs service manuals and some owners manuals
RevB
No. Unless you're trying to keep the rings from seating.
