J jpittman Forum Newbie Aug 11, 2018 #1 my push mower pulls hard and won't start. I pulled the spark plug out, and it still pulls hard. can you give me some ideas on what to do next? Thanks' Jerry
Russ2251 Well-Known Member Aug 11, 2018 #2 Check oil level. Check valve lash. Check flywheel brake for proper operation.
S shiftsuper175607 Lawn Addict Aug 11, 2018 #3 Russ2251 said: Check oil level. Check valve lash. Check flywheel brake for proper operation. Click to expand... What Russ said and check for debris under the deck
S shiftsuper175607 Lawn Addict Aug 11, 2018 #4 jpittman said: my push mower pulls hard and won't start. I pulled the spark plug out, and it still pulls hard. can you give me some ideas on what to do next? Thanks' Jerry Click to expand... When you pull the handle to start... does the cable move on the engine? This is what Russ is saying...is it releasing the brake?
