L Ldnakid Forum Newbie Joined Jul 16, 2017 Messages 1 Jul 17, 2017 #1 Is it better to an separate pump for each drive wheel motor or a single unit pump for both drive wheel motors?
BlazNT Lawn Pro Joined Apr 26, 2012 Messages 6,973 Jul 18, 2017 #2 With the choices you have given, 2 pumps are better than one.
cpurvis Lawn Addict Joined Aug 25, 2015 Messages 2,256 Jul 18, 2017 #3 I don't see a good reason for two. If you have only one pump and it fails, you're dead in the water. If you have two pumps and one fails, all you can do is pivot, which is the same as dead in the water.
