I just don't see an advantage using propane on small engines. I probably burn 30 gallons of gasoline annually, which is a lot of mowing for a "homeowner". Handling concerns, special carburetors, regulators, the lack of lubrication in propane all add up to it just not being worth the squeeze. Add to that, if you take it into a shop to have it repaired (heaven forbid:ashamed::biggrin
who is going to be qualified to uh, repair this one of a kind monstrosity?
