pollishpickle
- Jun 29, 2016
- 8
- 70
I just picked up a Pro Turn 460 with a Yamaha engine. The dealer was of very little help with the operation and since it was a replacement for a warrantied out Cub Cadet Tank he assumed I knew all about it. today I went out to mow and when I went to start it the engine would only spin about half a turn then freeze up it did this about 6 times each time I tried to start it and then the engine did turn over and it started. I looked in the manual for the proper starting procedure and there is nothing about this engine and I was doing everything just as described. I have used a Gravely before so I was pretty sure how to operate this unit. Once it is warm it starts normal. I let it cool down after I finished mowing and went back out and the same thing would only spin the engine about half way and freeze 3 times this time and then it started. What am I doing wrong
