Pro 12 - Attachment Connection - Spline verses Clutch
keg99
I just bought a Gravely two wheel Pro 12 that came with a 42" finish mower, brush cutter and sickle bar. The mower and brush cutter attach with a spline. The sickle bar has a slip clutch with a "tooth" connection, but no way to attach since it will not connect to the spline on the mower. I am concerned about connecting the brush cutter without a slip clutch. I had a Gravely Pro50 walk behind and currently have a Gravely 60" zero-turn. But the two wheel units are a new venture. Can anyone explain how I can convert to the slip clutch? And suggestions on where to purchase parts?
IThe mower and brush cutter attach with a spline.
I am going through the service manual and it looks like there may be a clutch built in to the housing holding the spline. So do I already have a slip clutch but it is hidden behind the spline?
Thanks for helping a newby to the two wheelers.
