turbofiat124
- Mar 23, 2011
- 288
Troy Built Pony, model # 13AN77KQ
Problem: I was mowing the other day, shut the engine off to get something to drink, came back and the starter motor would not turn over.
I checked the battery voltage: 12.6 volts
I did some troubleshooting and discovered the 20 amp fuse in the holder adjacent to the soldnoid was blown. Replaced it but still nothing.
After about 30 minutes of troubleshooting I found the only way to get the engine to turn over was to run a jumper wire (using jumper cables) directly from the positive side of the battery to the starter motor. With the ignition switch on.
Went to Lowes and picked up a new starter solenoid and ignition switch for a Troy Built. Replaced the solenoid. Nothing. Replaced the ignition switch. Nothing.
Blew after fuse at some point. But the fuse does not blow all the time for some reason.
Connectors for the safety switche on the seat and the one near the axle were unplugged when I got this mower by the previous owner. I plugged them back up and still nothing. There should be a third safety switch for the blade that maybe he did not unplug that switch has that gone bad? Maybe that is whats preventing the starter motor from turning. Or would that just ground out the ignition and cause the motor not to fire? I have not checked that one.
What else could it be? Could one of the wires going to the ignition switch be chapped somewhere in the wire loom? I'd really had to have to pull the loom out to inspect each and every wire.
What's confusing is there are five or six wires and five pins on the ignition switch. Why so many? Were do all of these wires goto?
Anybody have any idea why this happened all of a sudden?
