ThatGuyYouKnow
- May 1, 2013
- 60
Hey everyone i need some serious help. Our back up mower is still in need of a carb so im trying to keep my main going. It worked fine till about 5 or 6 months ago where it started not wanting to go to higher speeds. I figured it was the "timing belt" looking drive belt. I replaced it with a exact replacement and still speed has improved but if i push the lever all the way it stops half way. If while the mower is moving i push the lever all the way it will speed up but as soon as i let up is goes back to where it was before. It is also leaking trans fluid from the right rear shaft but its not a huge leak. Can anyone help? Only thing i know is its a automatic gentrans transmission.
