plastic gas tank rubber bulkhead fittings
butchfig8
Allis lawn tractor 712
Have rubber fitting that pushes into plastic gas tank bulkhead, steel gas line pushes inside the rubber with it.
Rubber is rotted where do I find replacment part ??
Cannot access inside of gas tank to install threaded bulkhead fitting
thanks
Most likely you are looking for Oregon part number 07-392 tank grommet. fits Dixon, poulan, and a few other brands.
butchfig8
Thanks looks like what I needed :smile:
Fish
Luckily those were pretty much the same between all of the old brands.
