Plant Selection in Landscaping
foxmowingact
Plants can make a huge statement in any garden. They are probably the most important single aspect in a new landscape or garden renovation. Plants can set the mood and style of the garden, draw you into different areas and create interesting views and features.
So it is important to have the right plant selection. To do this you should consider:
The Size of the Plant. Read up on how tall and wide the plants grow. Planting large plants in unsuitable places can be a costly experience.
The theme and style of your garden. If your looking to replicate a certain style such as Australian, Balinese, Country, Tropical etc then your plant choice should be a reflection of this.
The climate and location of the plants. Plants are suited to different environments, light conditions and soils. If the area is in full sun then you will need to choose a plant that can withstand direct sunlight.
How much maintenance is required. Some plants require more care, maintenance, watering, and general care than others. If you are not prepared to put in all the effort, choose plants that are drought tolerant and of a hardy nature.
Contrasting colours and textures of plants. Use your plants to give your garden a contrast of light and shade. Plants that have different thickness of leaves, colours or patterns can look great when layered into your garden creating different heights and bursts of colour.
So before you run to the nursery, do some research so that you choose plants that are suited to your area and will survive and thrive.
