Parts
ruready
I have a Ryan LA28 aerator that is probably around 20 years old. The engine is a kawasaki FE 250D. I was having trouble keeping it running. My local small engine repair shop said the problem is the coil igniter. We have tried to find the correct part but the kawasaki web site says that this part is no longer available and there is no replacement part. The part number is 21119-2143. I have been calling dealers but no one seems to have this part. Does anyone know of another place that might carry this part either new or used or any replacement part that could work?
What is the spec number of the engine? The ones I look-up is showing a three wire version.
Mower King
Some parts are just no longer being made and the only way to find them is, if someone has new, old stock sitting somewhere.
In reality....if a company made something that lasted forever and made the parts for it forever....they would never sell any new products!
Scrubcadet10
Moderator
Staff member
I would imagine that any other Kawasaki igniter will work, is it a single terminal? Igniters are basically an electronic points set that tells the coil when to fire, and people replace points system with similar igniters too.
Looking the IPL and wiring of the original ignitior it can be convert to a single wire Universal Igniter. But it would changing from bullet terminal to a F56 or .250 terminal.
ruready
It sounds like there is a possibility of converting to a different igniter. What could I instruct my small engine repair guy do do? Sorry, I am not a mechanic myself.........
ruready
Do you think part number 21177-2064 would work? It is also a 3 wire igniter...
Hammermechanicman
Don't know about that model in particular but you can replace the module with a mega fire ll moodule on the kaw engines i have worked on with dead ignitors.
