Export thread
Owners Manual
#1
J
Jasonsoccer08
Hi,
I have a Murray 12.5 hp 40" ride on mower. I bought it used and the deck gets caught on the wheel when in reverse on setting 4, 5 or 6. I an trying to find a schematic of the deck so I can figure out what parts are missing. Any help would be appreciated, Thank you.
#2
EngineMan
EngineMan
Is it the EMT Series, the more info the better..!
#3
J
Jasonsoccer08
I'm not sure. How could I find out? Is it located on the mower somewhere? I'll try to post a picture.
#4
EngineMan
EngineMan
Should be on the deck, only one that I have and that's for a 38" & 42" someone if not you has been looking for one on the web I see.
#5
J
Jasonsoccer08
I'm not sure how you can see that activity but yes I have been searching for the owners manual or a schematic of the deck. As is stands now, the deck of this mower has been "rigged" together and it would be fantastic to see what it is supposed to look like in it's original condition.
I'm having trouble uploading the picture of this mower from my mobile device so I'll upload from my laptop in a bit.
Thanks for your quick response
#6
J
Jasonsoccer08
I can not find any other markings except i can barely make out a 4E-GO next to the shifter.
Here are some pictures.
EngineMan
EngineMan
I can't see it being any diffrent apart from the 2" wider then that of the 38".
What parts are you looking for if any, or is it just the Owners manual you need.
#8
J
Jasonsoccer08
just the owner's manual. The deck gets stuck under the tire when i go in reverse. When I have the blade setting at 4,5 or 6. I cant seem to be able to move the deck forward an inch so it will stop catching the tire.
#9
EngineMan
EngineMan
Park it on the drive and set it to 4,5,or 6 now push the deck back (like laying on you're back using feet) and see where the play is, also look at the front hitch to see if there is too much play. maybe better if there was two of you, one to push the other to look.
